Cleaning Apexi Power Intake
Jono
Post by Jono »
Hi guys,
just wondering how do u clean Apexi Power intakes?
Or do you just keep buying new ones?
thanks,
Jono
Boris
Post by Boris »
Man Jono.....
Try this link: http://www.knfilters.com/clningins.htm
It's very similar, you can even use the K&N Special Oil to do it, unless you can find some Apexi stuff... :wink:
mxysxy
Post by mxysxy »
mmmmmm, 8O
The Apexi Power Intake is a maintenance-free dry-type air filter and will alleviate the problem of filter oil from "wet" air cleaners interfering with the air-flow meter
I thought you are not sposed to oil Apexi filters, just washing it should be fine.
But again, I am a newbie..... :)
Boris
Post by Boris »
Hmm, I take that back, I believe you are correct.... yes, indeed Jono's filter is a paper based filter that doesn't need oiling, well in that case just wash it! :oops:
jonowong
Post by jonowong »
what about hks superflow podfilters?
mxysxy
Post by mxysxy »
HKS claim that their High Performance Air Filter Systems offer the ultimate in both air filtration and air flow for maximum engine performance. The elements use a special oil to stop unwanted dirt particles from passing through the multi-layer polyurethane filter. Filters are thrown away when their lifetime has expired and are replaced with new filters, which are inexpensive and easy to replace.
jonowong
Post by jonowong »
inexpensive?
they're expensive for what they are!!
uas sells it for $65! thats heaps..!!!
ruchi
Post by ruchi »
HKS is also one of the dirtiest too :(
MIVEC is My Friend :D
tommy
Post by tommy »
jono! stop being a tight arse... u dont hesistate to buy a 15k car but when it comes to a 65 dollar filter change u cry ! :P
"pure adrenalin attached to a number plate... "
Jono
Post by Jono »
AY! wheres the post gone to??
i couldnt find info about whether apexi needs to be replaced every xxxxxlkms.. or just washed.. :?
Jono
tommy
Post by tommy »
huh?? the posts are sitll here
Jono
Post by Jono »
i mean,
the post topic is Apexi, and theres HKS
Jono
jonowong
Post by jonowong »
haha sorry for hijacking your thread... ill let you continue
