Engine bore?
TigZy
Engine bore?
Post by TigZy »
Hi there.
While I had this idea in mind for the Type-R I was originally going to buy, I was curious as to whether anybody knew of any technical documents or people who had bored out their FTO to a higher engine capacity? I know that in the Type-R department (2000 and below models) the engine boring out was limited (1.8L > 2L on a b18c3 was the safest to go to), but maybe the gain on an FTO GPX would be larger? Any help would be appreciated :)
Cheers!
-TigZy
salacious
Post by salacious »
I only know of one owner who has his engine bored out, he is in Japan and the website doesn't really go into much detail on it. He used to have a little more info in English but it is a 2.2L. Good luck with reading Japanese :)
http://www.geocities.co.jp/MotorCity-Circuit/1515/
TigZy
Post by TigZy »
Thanks for the help :)
He's got a nice FTO though... anything that will run a quarter mile under 13 seconds has my respects :p
Looks like I'll go speak to the guys at BD4's and see if they know how to do it.
Cheers!
-TigZy
HRD2BQT
Post by HRD2BQT »
have u ever considered doing frankie style?
swap your existing 6A12 Block to its bigger brother 6A13 Block. I dont know how much work is need to be done by doing this but I'm sure it'll be more practical than boring your existing ones.
Goodluck in finding one though....rare as!~
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
[url=http://z8.invisionfree.com/tgz_gc/index.php?showforum=23]J-Spec MotorWorks[/url] [b]<---click here [color=Red]NOW TAKING ORDERS!!![/color][/b]
Chiangstar
Post by Chiangstar »
i think the 6a13 block is actually taller than the 6a12 block... dont quote me on that.... but i was looking into it a while back and it actually is a lot more work and $$ as it seems to be...not just a straight swap...
simon
HRD2BQT
Post by HRD2BQT »
yeah it is taller but one of the guy from this forum has done the full 6A13 TT swap into his FTO so i dont think it' will be a problem.
As i said, im not really sure how much work is need to be done to do this. Being this two block is in d same 6A family - I'm quite sure this is far easier option than boring it out. Just to my idea anyway....
another option i could think off is using the crank, rod etc etc off 6A13. Basically simlar process to stoking d motor, but one thing 2 quote to is that 6A13 is design for Turbo (low comp), not sure if this can handle high compression head of the 6A12MIVEC.
some other guys in this forum may be able to explain this concepts.
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
TigZy
Post by TigZy »
Cheers for the help! I might start keeping an eye on jap import wreckers to see what I can find :)
Anyone else want to add their two cents?
-TigZy
salacious
Post by salacious »
Getting it bored is expensive since you'll need custom made pistons. You can get oversized pistons but at most you can increase the engine up to a 2.1 L. If you were turbo charging (over 9psi) it at the same time it would make sense since you'd need a forged pistons to take the boost.
dannyboyau
Post by dannyboyau »
HRD2BQT wrote:yeah it is taller but one of the guy from this forum has done the full 6A13 TT swap into his FTO so i dont think it' will be a problem..
Yes it is taller but it fits under the bonnet just if you leave the original engine cover off
HRD2BQT wrote:As i said, im not really sure how much work is need to be done to do this. Being this two block is in d same 6A family - I'm quite sure this is far easier option than boring it out. Just to my idea anyway.....
there is a 6A13 non turbo engine so if you were to get that and put the 6A12 mivec heads on it you wouldnt need to change your pistons and rods.
HRD2BQT wrote:another option i could think off is using the crank, rod etc etc off 6A13. Basically simlar process to stoking d motor, but one thing 2 quote to is that 6A13 is design for Turbo (low comp), not sure if this can handle high compression head of the 6A12MIVEC.
I have been looking into this and will let you know when i know if it is possible.
Stay tuned :lol:
HRD2BQT
Post by HRD2BQT »
Thankx dude.....looking forward to your update! :)
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
JagerMarty
Post by JagerMarty »
I know there is an Albury based FTO owner who has reboared his engine.
Don't know the spec's but apparently he's had a great result with it.
Unfortunately I don't think he gets on here so info is limited.
wildfaye
Post by wildfaye »
How about a bottom 6a13 block + 6a12 mivec head.
rebored out to 1mm bigger using stock oversized mit pistons?
effectively meaning a 2.6-2.7L mivec? :roll:
Black_FTOGPX
Post by Black_FTOGPX »
I know this may be a dumb question, but has anybody looked at getting a custom block casted? As this way you could have the bore huge and the stroke the same, so the engine would not be taller. So you could have a 2.5 lt without any clearance problems
salacious
Post by salacious »
The redline on the 6A13 I think is either 6.5 or 7K rpm which I think is down to the crank. If you rev it higher it might fail. This is one advantage of the 6A12
dannyboyau
salacious wrote:The redline on the 6A13 I think is either 6.5 or 7K rpm which I think is down to the crank. If you rev it higher it might fail. This is one advantage of the 6A12
The 6A12 and 6A13 cranks are almost identical except for the stroke
I redline for the VR4 is 7500 i have my 6A13 Rev limiter set to 8500 and i have hit the rev limiter many times with 18 Lb boost, the only thing that has failed so far are the pistons due to detonation. I have been driving it now for over 18 months with about a total of 8 weeks off the road.
dannyboyau
wildfaye wrote:How about a bottom 6a13 block + 6a12 mivec head.
1mm oversize will make the 6A13 a 2.55 Ltr engine
dannyboyau
Black_FTOGPX wrote:I know this may be a dumb question, but has anybody looked at getting a custom block casted? As this way you could have the bore huge and the stroke the same, so the engine would not be taller. So you could have a 2.5 lt without any clearance problems
Custom block would be extremely expensive and not really worth the effort
Also the bore on the 6A12 is already bigger than the stroke, so you need to develop a stroker kit, so effectivly you need to cast a new crank or get the 6A12 crank stroked, It can be done but it is expensive as it involves getting the crank journals welded and then getting the crank reground to the desired stroke then you need to make custom rods designed and made to suit the new crank. Lots of time involved and time is money. Also the guys that do this type of work charge big dollars unless they are doing it for there own race cars or close mates.
smorison
The Godfather
Post by smorison »
how hard is it to bolt the 6a12MIVEC heads onto the 6a13??
what's involved
Black_FTOGPX
I priced up a 6A13 block and it's looks like the cheapest place is NZ, they wanted $1500 for a Complete 6A13 Na SOHC engine or $750 for just the the block.
wildfaye
Post by wildfaye »
I have absolutely no idea if it'll fit, but it sure sound delicious ain't it! :twisted:
