shaking...
- ANBU_fto
shaking...
hi guys
i just changed my petrol from optimax to mobil 8k, and i noticed a little change....
when i had optimax and took off slowly, and because i have a manual, it took off pretty smoothly, as in when im in complete stop, check it in gear one and slowly just let it roll, and it would do it smoothly. now that i have molbil 8k, when i do that, my car starts to shake soooooooooo bad.... it scares me... feels like shes hurting or something. has anyone experienced this problem? is it easy fix?
...groOl...
08 Evolution X - White
97 Gpx Fto - Racing Red
Optimax leaves behind a residue that might take a couple of tanks to clean out. You can possibly accelerate this process with a fuel system / injector cleaner.
You might also find that the car is re-adjusting itself to the new fuel. It can take around 100kms for the car to adjust itself when a change is made, alternatively you can reset the ECU to clear its memory.
MIVEC is My Friend :D
- ANBU_fto
kekek i knew RU SHEE would come to my aid!!! kekek jks dude
but is it normal for it to be doing that.... sometimes it doesnt happen... oh and i just forgot, it started to shake heaps when i also had a full car today, but when i was driving by me self, it didnt shake as much
...groOl...
- FTO338
hmmmmm i didn't had a problem what so ever when i switch from Optimax to Ultimate for my other car. I use Ultimate from day one for my FTO though.
- jonowong
I'm currently trailing BP Ultimate at the moment (from Optimax).
This is the first time I'm using the BP fuel and I didn't get any funny reactions from the FTO.
The only complain I have so far is that it was about 4 cents more than Optimax (at my local servo).
I'm keeping a close eye on the mileage I'm getting from BP as opposed to Optimax and see how I go. Probably need a couple more tanks to clean out as much Optimax from the system as possible though.
But as far as performance wise, so far it's not something I can notice from day to day driving.
From FTO to EVO......
- ANBU_fto
guys i dont think its the petrol that is making my car shake so bad!!!
the shaking is like when... um.. somethings u dump the clutch it has this little jumping effect, but in my case my car shakes so bad it hits like a 8.5 on the rictor scale.... someone help me.... i like driving manual.... i might have to switch to auto now... till my car is fixed....
...groOl...
