Loose air pipe?
erfdan
Loose air pipe?
Hey
I randomly just noticed this loose air pipe that seems to be sucking air that isn't connected on one side? And I can't seem to figure out where the otherside is suppose to be connected as I don't remember it ever being like this. Would anyone be able to help me?
Thanks in advanced!
Thanks in advanced!
- received_289151505232876.jpeg (223.74 KiB) Viewed 7185 times
- aza013
- NSW Coordinator
Re: Loose air pipe?
Have you taken your air intake off at any time?
It's been some time since I have looked in the fto bay, but I think the other end plugs Into the intake pipe.
- bjk
- Totes
Re: Loose air pipe?
I don't think that's the breather pipe, from the EPC data kinda looks more like the one that plugs in by the fuel rail?
- spetz
Re: Loose air pipe?
I believe it could be the fuel pressure regulator vacuum hose?
Re: Loose air pipe?
Never mind that, replace your radiator cap for f**k sake
erfdan
Re: Loose air pipe?
Hmmm I'll check some of the spots out thanks. If it helps when I put my thumb over the end, the car idles lower than when it does when it's just sucking air in.
- aza013
- NSW Coordinator
Re: Loose air pipe?
bjk might be the winer on this one
- Nacho
Re: Loose air pipe?
+1 runs to fuel pressure regulator
erfdan
- bjk
- Totes
