Replacement rear bearing advice needed!
GazGPvR
Post by GazGPvR »
Guys my rear bearing needs to get changed on my GP. My model is 1998.
All I can find on eBay is up to a 1997 model. Would this be the same part?
Thanks! :D
Gaz
Re: Replacement rear bearing advice needed!
Iirc they are different
GazGPvR
Post by GazGPvR »
They're not the same part bjk?
Gaz
Definitely different. What's your VIN number? DE3A...... etc
GazGPvR
Post by GazGPvR »
I was told that all the rear non ABS bearings are the same. sh*t, I just bought one last night.
Yes, DE3A... 6A12 etc. I don't know the full VIN number
Gaz
VIN will be stamped on the firewall in your engine bay likely or on a plate
GazGPvR
Post by GazGPvR »
Is it ok to put my vin number online?
Gaz
GazGPvR
Post by GazGPvR »
6U9000DE3A0300488
Gaz
I haven't got a PC with ASA (parts catalog) available at the moment to confirm, so can you tell me if the car has ABS or not?
GazGPvR
Post by GazGPvR »
It definitely doesn't have ABS Bennoz.
Gaz
Rob Furniss
Post by Rob Furniss »
Well it is a GPVR 5 speed Auto made in March 1998, are you sure it doesn't have ABS, does it have a larger brake booster in the engine bay?
MR316500 is the part number for the rear hub if it's ABS.
https://www.viamoto.co.uk/proddetail.ph ... %2F1997+on
GazGPvR
Post by GazGPvR »
Hi Rob. Yes I'm sure it doesn't have ABS. I've tested the brakes tonight. Plus I've checked the fuse box and it doesn't have a fuse slot available where the ABS should be. No ABS symbol light on dash either.
Is it only showing a part number for an ABS model?
Thanks for the help and info mate.
Gaz
GazGPvR
Post by GazGPvR »
I think it was the GPvR Aero that came with ABS as standard. Then the GPvR came with LSD as standard.
Gaz
Rob Furniss
I thought all late 1997 onwards were ABS that's all and yes only showing the ABS part number, i'll check again in a bit though.
GazGPvR
Post by GazGPvR »
Thanks Rob, appreciate the help. I took a photo of my fuse box and there are no fuses where the ABS fuses should be. Is it possible that the previous owner took them out somehow? How can I upload a pic?
Gaz
GazGPvR
Post by GazGPvR »
Pic of my fuse box
Pic of my fuse box
Pic of my fuse box
Gaz
Rob Furniss
That could just be your missing the relay mate.
Bang on a pic of your brake booster and have a look down near the battery tray / firewall for the abs valve block thingy.
Rob Furniss
Here's a pic of the different brake boosters, ABS one is larger and has like a double hump
FTO Brake booster - standard and ABS.jpg (50.68 KiB) Viewed 14192 times
GazGPvR
Post by GazGPvR »
Cheers for that Rob. So I got my rear hub bearing changed today. It turns out I don't have ABS. I bought two hubs as I didn't know what would fit. The non-ABS fitted... Sent the ABS one back today. I was just about to buy the relays and fuse. I'm a bit disappointed it doesn't have ABS!
Gaz
If you don't have ABS then it either isn't a version R or it's been removed.
