Do i need a new clutch with an lsd box
Mivec swapped gx
Post by Mivec swapped gx »
Just bought an lsd box mith i think a cusco mz diff in it will the fto standard clutch handle the torque or will i need a heavy duty in it
Re: Do i need a new clutch with an lsd box
The LSD isn't giving you any extra power :lol: although if you want to do upgrades in future, now would be the time to get a HD kit in there.
Mivec swapped gx
So the standard clutch is good enough to keep for now
If all you're putting it standard power through it and the clutch is still good I guess. I'm no expert though lol
Wouldn’t you change the clutch though given that you’ll be doing a box swap and your car likely still has the 20 year old clutch in it or if not a very old one
Mivec swapped gx
It had a seconhand box put in just over a year ago so not sure if the clutch was done then will have to check the receipts i got with it
