The plan didn't work but he had the right idea.Bennoz wrote:Overall plan, is to do this on a budget & quickly. Keeping as much of the 6A13 as stock as possible.
My tentative budget is $10k, and I think (hope) the final figure will end up being pretty close. That's based on what I've spent thus far, and what I've been quoted for installation, fabrication, and everything else to take the pile of parts that have been accumulating in the corner of my room and fashion them into a functioning conversion.
Here's the current list of acquisitions and prices (updating gradually):
Exedy HD clutch - $360
6A13 engine & ecu - $650
Spare turbos - $450
Timing kit - $300
Gaskets & seals - $300
Protex water pump - $55
Hydraulic lifters - $242
Denso VK22 spark plugs - $100
Wiring loom - $100
Walbro 255 fuel pump - $85
Drive belts - $68
Oil filter - $17
Brake fittings - $77
Intercooler - $273
Fuel rail adapter - $9
Evo 8MR BOV - $157
MAF - $80
GR rocker cover - $70
Mamba tee for oil pressure - $40
Boost gauge fitting - $12
Gauges - $300
Battery box - $33
HEL braided brake lines - $117
Top Gun ignition leads - $104
Brake hard line - $32
Evo 6 steering rack - $275
Steering reco - $465
Alternator loom - $70
Ceramic coat - $500
Trans & brake fluid - $111
Engine oil (12L) - $74
Coolant & P/S fluid - $24
Gasket maker - $22
Driveshaft seals - $38
Vacuum line - $20
Turbo oil return pipe gaskets - $15
Turbo compressor cover gasket - $6
Misc for P/S res - $23
Wiring & spades for gauges - $24
P/S hose for rack - $30
Washers and bolts for rack, spacers, wastegate - $10
Extend actuator rod - $10
TOTAL: $5748
The pile as of today:
After abusing my bank account for the better part of a year I'm almost ready to pull the trigger. Just waiting on the gauges from the US, flanges for the custom dumps and a few other bits'n'bobs to arrive via VecTec, for Driven Motorsport to have a spot in the workshop whereby they won't have to shuffle the car around for a few weeks, and probably to get a Statement of Requirements from the DPTI via an engineer to pave the way for making it legally compliant.
Watch this space to see a nugget turn into a slightly faster nugget.
Gonna dump all the pics on flickr here:
