Catalytic Converter
Catalytic Converter
Hi guys,
I have a mildly modded MIVEC motor (P&P heads, 5mm oversize TB, extractors, exhaust and ECU).
How restrictive would the catalytic converter be at this stage if anyone knows?
I do not plan to drive the car on the street (just track) currently and was considering about just knocking out the cat internals as a free "high flow cat" upgrade.
Is this a bad idea at all?
Re: Catalytic Converter
Yeah just do it
No cat is the best type of cat
I think it was Aza who netted pretty reasonable gains via decat.
Spike28278
Post by Spike28278 »
How much did the port and Polish cost btw?
Sent from my SM-G930F using Tapatalk
I believe it was in the $1,600 range but that was a complete rebuild of the heads including new valve guides, 3 angle valve cut etc + the intake runners were match ported to the heads
EDIT:
Just read that thread. 10kw gain is pretty impressive from just a decat.
Does anyone know the restriction difference between decat and high flow cat?
