Did you know? Headlight difference between GPX & GPvR
DODO``
Post by DODO`` »
See pic. GPX has 3 connectors into the leadlight unit and GPvR has 2.
I'm also selling this HID headlight that came with the car and moving to factory one. Ill do a straight swap with factory headlight in good condition if anyones interested. Will put up more pics.
Sent from my D5833 using Tapatalk
Re: Did you know? Headlight difference between GPX & GPvR
I must admit I'm not sure what I'm meant to be looking at here haha.
Yes, GPvR came with factory HIDs.
Was also a factory option for the other models.
And the extra connector is a facelift addition. Not GPvR.
It is for the parker, prefacelift models had the parker in the fog light/indicator assembly.
DODO``
Post by DODO`` »
Vectose wrote:Yes, GPvR came with factory HIDs.
but the one came out of my GPvR isnt HID! Its got halogen bulb with no ballast??
most likely removed during compliance when it was first brought into the country.
Yeah, it's been removed. You can see the mounting points for a ballast on the bottom. They're definitley HID housings.
DODO``
Post by DODO`` »
AHHA now it makes sense.
I thought they replaced the entire headlight. did know you can keep the housing & change out the bulb alone!
Id love to swap these two over between GPX & vR..
Do you reckon it can be done?
GPX has 3 wire connectors and vR has 2
