New to owning a fto
Websta14
New to owning a fto
Post by Websta14 »
Hey ladies and gents, just recently bought a fto and I have a feeling that it has been thrashed, what are some things I should check over to know if it will last me a while or if I need to get something fixed( preferably the major parts)
Hope to hear from use soon!
Cheers :clown:
Websta14
Re: New to owning a fto
Post by Websta14 »
its a 5 speed manual btw :)!
Wttc! Hopefully it's not as bad as you think. What are the symptoms?
Welcome to the club. Yep, need info and pics to be able to answer that question.
    Websta14
    Post by Websta14 »
    It's not bad but I had a mechanic look over everything and he only found engine mount starting to split witch I'm changing soon, small engine leak witch I still have to find :/ lol
    Boot covers cracked and just a militia be bush on right side and normal on left side. Just the gear changing seems a little rough, nothing heaps noticeable but it just feels different from the other cars I have owned haha could be nothing but what are some of the main things that go wrong with fto"s
    Oh and how do I tell if it's a gpx etc? Haha the last owner just told me it's a fto
    Websta14
    Post by Websta14 »
    Nolothane bush*** on right side
    Sounds like it just needs some maintenance. Easiest way to check if GPX is if the oil cap is on the left hand side of the engine.
    Websta14
    Post by Websta14 »
    bjk wrote:Sounds like it just needs some maintenance. Easiest way to check if GPX is if the oil cap is on the left hand side of the engine.
    Yeah mate it's on the left hand side, sorry I'm new to fto"s and parts of the car in general I've only done smaller things to cars haha
    Changing the gearbox oil may well help with the gear changes. Oil leaks arent uncommon. Engine mounts and CV/rack boots commonly need changing (Ebay). You should think about doing the belts and plugs when you fix the oil leak.
      Websta14
      Post by Websta14 »
      Ohkay yeah sweet I will do all that, what's the best oil to use for the gearbox oil ? Thanks heaps mate!
      Theres an oil thread on the forum somewhere. It has more info than you could ever want. Havent got the link handy atm, but search for oil thread and you should find it.
        Websta14
        Post by Websta14 »
        Orite no dramas. Thanks heaps!
        P.s do you know any good mechanics in Sydney I could take my car too?
        Bleed the clutch line and change the box oil
        Websta14
        Post by Websta14 »
        silverGPX wrote:Bleed the clutch line and change the box oil
        No idea how to do that haha
