MIVEC not kicking in YO!
DODO``
Post by DODO`` »
Video above shows MIVEC not kicking in... haha. This video is of first gear and same thing happens on 2nd gear too.. (2nd gear not recorded)
why,, oh why..!?! would anyone be able to tell what is going on?
:( help!
Re: MIVEC not kicking in YO!
Wait for someone smart to chime in but, oil level good? Definitely GPX alternator? Tried in second gear? (I find it easier to tell)
Is engine at operating temp?
DODO``
Post by DODO`` »
Oil level is just below full level.
Just contacted previous owner and said he hasn't changed or fixed an alternator.
Not recorded but yup same thing happens on 2nd gear.
Fully warmed up engine.
Sent from my D5833 using Tapatalk
Let the car warm up correctly, needs to be the correct oil temperature, and oil pressure. Let it run for 5 mins before trying to drive with MIVEC. If that doesn't sort it then you need to check your Alternator, needs to be the 110A alternator with 4 pins., make sure it's plugged in correctly, and make sure all 4 pins are intact and not damaged.
DODO``
Post by DODO`` »
Yes sir. Ill check it as soon as o get home from work. How do u know ita 110A? Is it written anywhere?
It should be printed it or on a plate stuck to it. If it's 4 pin it'll be the 110A mivec, if it's 2 pin it'll be the 90A non-mivec
DODO``
Post by DODO`` »
Couldn't get my hand in so I couldn't take the plug out but the plug had 4 cables.. might take it too the shops to check!
Check for codes.
Many things can stop mivec, ZFLA5H's FTO did this because one of his injectors wasn't plugged in correctly.
Shhhhhh that was a secret [FACE WITH TEARS OF JOY]
Sent from my SM-G930F using Tapatalk
ZFL45H1 wrote:Shhhhhh that was a secret [FACE WITH TEARS OF JOY]
Key word "was" :lol:
Sorry
PHIL069 wrote:Check for codes.
Codes never picked up my MIVEC problems, but yea that's also another good place to check, but my money's on alternator
DODO``
Post by DODO`` »
Lol thanks!Image
So this was the view from the top.
The plug was covered in oil.
Surely this can't be normal aye..
