Can someone confirm if I have this sequence correct for diff bearing preload?
After replacing bearings on diff place plastigage or solder in box casing
Install spacer and inner race
Install diff and clutch housing with outer race
Install case bolts (original) and torque to spec
Separate case again and remove diff
Remove inner race and spacer
Check width of plastigage or thickness of solder
If out of spec replace spacer
Reassemble box
Differential preloading
Re: Differential preloading
Yeah, so you essential put it all together with solder as the shim, then pull it apart. Vernier the solder width, then install shims of the same thickness.
So the shim that came in the box is not placed for the check just the solder?
Correct.ftonoob wrote:So the shim that came in the box is not placed for the check just the solder?
