Which cylinder is number 1?
- Funugs
My car wont start after a timing belt job, there's no valve piston interference and it cranks over fine but just wont start, everything is plugged in correctly and I dont know what else could be the problem. I want to verify that the painted on timing mark on my crankshaft is correct, so which cylinder is supposed to be at TDC when the crank marks line up?
Re: Which cylinder is number 1?
Number 1. Hence the term, top dead centre lol
It's the rear left cylinder.
- ZFL45H1
I've had this trouble before. It turn out being the crank angle sensor
- Funugs
Im not too keen to take the intake off again. Isn't each rear cylinder sync'd up with a front cylinder?Bennoz wrote:Number 1. Hence the term, top dead centre lol
- Funugs
Thats what im leaning towards, can you elaborate on what was the problem with the sensor and how u fixed it?ZFL45H1 wrote:I've had this trouble before. It turn out being the crank angle sensor
- Funugs
I have been going off the white paint on the tooth at the top, but after I cleaned the sprocket I noticed there is a circular indentation below the tooth at the bottom, is this the actual timing mark??
fuckkkkk
fuckkkkk
- ZFL45H1
So basically what happened to my sensor was while doing a complete rebuild on my old fto we didnt 100% correctly align the sensor with the cam gear and the metal piece that passes through the sensor therfore ripping it apart
