Electronics not turning on bc key fob not working
- JacksonChater
They key fob that turns the electronics on and locks/unlocks doors isn't working so I can't start my car. Is there anyway around this? This is the fourth time it's happened
Re: Electronics not turning on bc key fob not working
Rip out the alarm. Thats what I had to do when mine died.
Yep same here.
- JacksonChater
Would i be able to do that myself or would i be better off getting an auto electrician on the job?
Depends how good you are with a soldering iron.
- JacksonChater
I did a year of electrical engineering at tafe? Used them a few times
Yeah you'll be right then. Just remove any alarm wires and solder the wires back to their original partner wires. i.e. color to color on the factory wiring loom and you should be gravy.
- JacksonChater
Yeah but where is the immobiliser at?
Under steering wheel next to footwell fuse box will be where all your wires are usually.
- payaya
Just get the two i ignition wires solder them together and pull the alarm fuse! Don't worry about ripping it out.
Unless you have a milultipoint alarm.
