Hi I had my fto up on ramps doing a oil change and
had a quick look at steering ect and noticed couple of steering boot rubbers split, cv ones fine!
Im not sure what was split but does anyone know the rubber boot sizes and where to get them
Please?
Rubber boot sizes for steering, tie rod end ect?
Re: Rubber boot sizes for steering, tie rod end ect?
http://m.ebay.com.au/itm?itemId=380467562070
isnt that thread on cv boots as mines ok, im after steering rubbers, not sure on
Names but couple my small rubbers split each side
Just go to your local auto parts and get some universal boots.
You just cut the ends off to the diameter you need.
Bennoz wrote:Why do I feel like I answer this question on a daily basis...Daniel2019 wrote:Anyone got new ones lying around/cheap source? Would rather buy off someone who has extras than somewhere else. Anyone? If not, to fleabay I go.
Steering rack boots - Generic - Supercheap/AutoOne/Repco etc
http://www.supercheapauto.com.au/online ... 3002#Cross
CV boot - dont be a tight arse, spend the $39 on eBay, replace the whole joint. Kit comes with boot, grease straps, everything.
If the boot is that old that it's worn itself a hole, chances are the joint is worn as well.
http://www.ebay.com.au/itm/Mitsubishi-F ... 0b7&_uhb=1
