downshifting in tip
- fto617
downshifting in tip
hey guys
for those of yous with tiptronic FTO
i jsut rebuilt my gearbox and i dont want to kill it again
jsut wondering...
if u brake, do u guys downshift from 4th to 3rd to 2nd ?
or is it not good for the gearbox?
thanks
coz i downshift like the way i would on a manual.
jsut wondering...
thanks
- jonowong
When you downshift you are increasing the load on the engine significantly which can lead to things getting damaged, wearing out or breaking. I would only suggest using the engine to help slow you down in emergency braking situations or on the racetrack (or when having a bit of fun) but not as a normal day-to-day braking technique.
MIVEC is My Friend :D
- rxboy
Valid point but what we're talking about is downshifting so as to use the engine to help improve braking, this is different to downshifting to be in the right gear for taking off again. With downshifting to improve stopping you'd downshift at a higher rpm, while downshifting to be in the right gear when accelerating would be done when the revs have reached a lower rpm.
- payaya
The tiptronic wont let you change down if it's going to do any damage to the engine at too high revs. The same as changing up gears in tiprtonic, it wont let you if your've going to slow.
The cars just protecting it'self and being smarter than the driver...
What annoys me the most in an auto/tipronic FTO is it stays in 3 gear way so long when slowing down, so when you go around a corner or need to go get out of the way of something quickly it bogs down, when it should already be in 2nd gear... Bad gearbox programming... but this is when tiptronic comes in handy.
- payaya
no gearboxes shift down from 4 and go thorugh all the gears, till it gets to 1st gear.
Also we know all gearboxes have a protection mechanism, when if its really required to accelerate out of a corner quickly use full auto mode, simple.
Also at 15km/h slapping it back to first gear is never going to be a problem.
- smorison
- The Godfather
I tried this out yesterday and to me this seems to be quite smart gearbox programming as the car reacts differently depending upon how fast you accelerate.nofearzz wrote:What annoys me the most in an auto/tipronic FTO is it stays in 3 gear way so long when slowing down, so when you go around a corner or need to go get out of the way of something quickly it bogs down, when it should already be in 2nd gear... Bad gearbox programming... but this is when tiptronic comes in handy.
If you accelerate slowly the car stays in the higher gears providing a gentler ride whereas if you floor it the car drops back to first and gives you all the speed you need.
- FTO338
I agree, but its still slower compare to using the tip, plus the auto doesn't goes to the redline, well at least mine doesn't.
- smorison
- The Godfather
it doesn't go to redline... it goes to where the power drops off (just before redline)... its actually shifting at the optimium shift point... My RSM's shiftlight (starts flashing) is set to go at 7500RPM by the time i react to shift (in 1st gear) it's at optimium shifting point (7900-8100ish) ... and doesn't bounce of the rev limiter...(well normally not). obviously i have more warning in second and thirdruchi wrote:really? I'll double check mine, but I'm sure if I floor it in 1st or 2nd it goes all the way to redline or at least very very close.
- smorison
- The Godfather
