Power steering
Power steering
Just lost power steering intermittently while parking this morning. Rapidly came on and off while reverse parking then came back on. Me thinks pump buggered? Any ideas guys?
And yeah fluid is full.
Re: Power steering
Belt slipping..
Re: Power steering
Re: Power steering
Belt doesn't screech, and its new. I think pulley or pump.
Re: Power steering
Pump doesn't 'sorta work' intermittently, it either fails or it doesn't. Also, did you bleed the system properly when you refilled the fluid?
Re: Power steering
And if you've just replaced the belt, that's even more telling. What's the total lateral play in the centre of the longest point to point span of the best?
Re: Power steering
PotatoBennoz wrote: What's the total lateral play in the centre of longest point to point span of the best?
Re: Power steering
destinationtoby wrote:PotatoBennoz wrote: What's the total lateral play in the centre of longest point to point span of the best?
- SchumieFan
Re: Power steering
This is the problem... The deflection needs to be checked from the bottom at the longest span. ... As per manual
Re: Power steering
Intredasting. Will check 'sarvo.
Re: Power steering
Because you can always just chuck a long edge rule down there & measure it in carSchumieFan wrote:This is the problem... The deflection needs to be checked from the bottom at the longest span. ... As per manual
Re: Power steering
Just fuckin do er up til she tite
- SchumieFan
Re: Power steering
Euphemism?Bennoz wrote: Because you can always just chuck a long edge rule down there & measure it in carAlways thought that's a rubbish way to do it.
