Samco radiator hose auto $20
Few months old
In perfect condition
It's the lower & longer hose
They were nearly $200 for a set from memory off eBay .
Asking $20
Cheers
Also have a good condition radiator for $80
Asking $20
Cheers
Last edited by destinationtoby on Tue Sep 24, 2013 2:38 pm, edited 3 times in total.
Re: Samco radiator hose auto
Just FYI quickly, pretty sure the only difference is the bend in the lower one.
Correct, tops are the same.Daniel2019 wrote:Just FYI quickly, pretty sure the only difference is the bend in the lower one.
manual bends the other direction than the auto.
Both 4spd and 5spd auto are the same lower hose.
This also applies to non Mivec 6A12 FTOs. But not 4 cylinder.
n00bs covered.
and manual ones fit on the auto but not vice versa
Yes, but the lower hose gets cooked because it sits up against the gearbox.Sahin wrote:and manual ones fit on the auto but not vice versa
Current issue with smurfy which is why I'll be swapping with SN000R.
Yes but I'm probably going to have to buy the whole kit new for the manual.. So will sell this lot.
True, true. Just swap the bottom one if you find someone wanting to swap though. If you had've got to me last week then I would've swapped.destinationtoby wrote:Yes but I'm probably going to have to buy the whole kit new for the manual.. So will sell this lot.
Just get a normal bottom one... you cant even see it
DamnnDaniel2019 wrote:True, true. Just swap the bottom one if you find someone wanting to swap though. If you had've got to me last week then I would've swapped.destinationtoby wrote:Yes but I'm probably going to have to buy the whole kit new for the manual.. So will sell this lot.
Does anyone know where I can source the same blue samco hoses new?
Last lot I got were off eBay, don't think they're on there anymore
They're better than the standard ones aren't they? Or I could just swap my lower manual one for a lower auto one like a normal person...Sahin wrote:Just get a normal bottom one... you cant even see it
They are much the same lol just look better they dont do anything differentDaniel2019 wrote:They're better than the standard ones aren't they? Or I could just swap my lower manual one for a lower auto one like a normal person...Sahin wrote:Just get a normal bottom one... you cant even see it![]()
Yes they are way better.. Fitted a couple different ones today.. The Samcos feel way better qualityDaniel2019 wrote:They're better than the standard ones aren't they? Or I could just swap my lower manual one for a lower auto one like a normal person...Sahin wrote:Just get a normal bottom one... you cant even see it![]()
They don't get anywhere near as hot and don't get weak and bendy (no movement) when they are hot..
They fit tighter, won't ever split, and yeah, look mardd
The normal ones dont get hotter
whatever you think mate
I dont think you've felt a normal new one
....and they don't even come in red
Coolant hoses are coolant hoses, you replace them when they are getting old, say every 100,000km
They doSahin wrote:The normal ones dont get hotter
Very true. A new one for amayama for $24 is great and will last me ages.PHIL069 wrote:....and they don't even come in red![]()
But I want the samco one again. Just Because .
Sahin wrote:I dont think
Sahin wrote: whatever you think
Just stop thinking
- kiz
- SA Coordinator
They do mate, they come in heaps of colours, even camoPHIL069 wrote:....and they don't even come in red![]()
You just have to custom order them;
http://www.samcosport.com/uk/colours.asp
1998 Mitsubishi FTO GPVR AERO
