Where do you put your amps?
do u guys keep it next to the sub? on the box? under the seat?
anyone put it where the spare tyre is? if so, how did u do it and do u have any pictures?
- SilentBob
mine is a nifty little place
I own an Audison srx3(i think thats the model) which happens to be a rectangular shape
the same rectangular shape that is on the vertical part of the rear passenger seat footwell..(eg where the rear passengers back of their legs would be if they were sitting in the back)
it fits so nicely and snug, and allows me to easily hide all the cables under the back seat...and is also practically invisible to see from anywhere in or out of the car
so...thats where mine is
SilentBob
SilentBob
- Bluntman
- SilentBob
- veilside
http://www.ftodiy.co.uk/ is the site ya want
I have my amp for my front splits in the boot. Just run the cables under the carpet
Mine is under there, along the passenger side as close to the wall as you can get it, then up under the backseat and into the boot. Easy enough to do!
- SchumieFan
- RichardH
- RichardH
Just MDF and some Jaycar speaker carpet stuff. It was actually pretty straightforward once I got into it!
The sub went on the right, with the driver facing the right rear corner of the boot, and the port facing the left rear corner. My options were very restricted, as I needed to have room for a pram in there too!!!!
I fitted two L-shaped brackets to the rear of the sub box, and it bolts onto the rear strut brace through the holes. I raised it up a bit too. The whole thing slots in quite tightly! Not a millimetre to spare.
- Rich
- Rich
- RichardH
Think it's short for "multi-density fibre". Basically, a composite wood-style panel you can buy at any DIY or hardware outlet.
Very easy to work with. Screw-and-glue construction always gets good strong results.
You can cut it with a jigsaw (as I do), with a proper high speed circular saw, or whatever.
But it's VERY important to wear a mask when cutting mdf. The fibres are extremely fine when cut by a high speed tool, and are really dodgy when it comes to lungs. Think asbestos kind of dodgy. So buy a pack of disposable masks when you buy your mdf, and cut it in a ventilated area.
- Rich
- Rich
