Grounding
Grounding
Can someone tell me where the factory grounding location is? i've got a bad ground some how because i did a gearbox swap and i'm not sure i've gotten it where it's meant to go
as in the battery ground
Re: Grounding
Find a bolt, scrape a little bit of paint of, boom a ground?
I think...
I think...
- spetz
Re: Grounding
What are you trying to ground?
Usually when you add something like aftermarket head unit, amp, gauges etc, you just ground the the chassis.
Re: Grounding
Did you read my post even somewhat?
Re: Grounding
It's on the gearbox, pick one of the housing bolts (centre join of gearbox housing sections, not box to block housing) that's near the slave cylinder. That's the factory earth spot.
Re: Grounding
Yee! I was rightBennoz wrote:It's on the gearbox, pick one of the housing bolts (centre join of gearbox housing sections, not box to block housing) that's near the slave cylinder. That's the factory earth spot.
