Closed.
- SchumieFan
Re: FREE: 1995 GPX Air Con and Power Steering Stuff + Stock
I'll take the air con/heater control unit!
Weight reduction
Ill take the compressor and condensor off your hands.
- SchumieFan
Oh man u suck!
Thought my prayers had been answered
Doesn't yours just need globes?SchumieFan wrote:Oh man u suck!
That's an easy fix.
- SchumieFan
The mod I did on the RVR should work on the FTO.
Never did do the Climate controller as our globes worked.
http://www.completervr.com/viewtopic.php?f=23&t=45
http://www.completervr.com/viewtopic.php?f=23&t=22
Main thing you're looking at is the disassembled unit showing the globes, and the globe bases I used in the clock/ compass unit.
Pretty sure they were the same globes, therefore the bases are the same.... SO, you could use T5 globes which are universal.
- SchumieFan
Yeah but where to buy T5 globes that aren't LED'S?!
- kiz
- SA Coordinator
Narva make them mate, find a Narva retailer, they come in a little blue box of 10/20. If they tell you they don't do it then tell them they are bullshitting because at my previous work I used to sell about 40 different types of Narva bulbs and there are a few different T5 ones. Cost price is like $8-$10 for a boxSchumieFan wrote:Yeah but where to buy T5 globes that aren't LED'S?!
1998 Mitsubishi FTO GPVR AERO
- SchumieFan
no worries... ill keep looking for bulbs... sorry to pollute your thread!
- vipfto
need the bracket that holds evaporater (near battery) and dam you dwayne i need a compressor and all back to cool a/c glory..... but if you sell it dibs
- vipfto
Well I need both those bits all im missing for nice cold air in summer
give them to vipfto. I may need the compressor, but wont find out till summer so ill bow to the greater need.
I have a compressor. $50 if ya want
- vipfto
dstocks wrote:give them to vipfto. I may need the compressor, but wont find out till summer so ill bow to the greater need.
you sir are a gentleman
Sounds reasonable. Ill take it as long as postage isnt horrific.I have a compressor. $50 if ya want
