tiptronic -the best revs ?
- andie066
hey dose anyone know what the best revs are for a tiptronic?
and is it faster than using Drive? also dose the rev rage alter with GPX and GR Fto's?
tip mode will give you more control as you can choose the point at which you change gears, but in terms of performance there will be no difference between tip mode and normal auto mode.
If you floor it in auto mode, it should go almost all the way to the redline before changing, just as you would do in tip mode anyway, if dragging someone off.
If racing on a circuit with corners and where you'll be both accelerating and braking, tip mode will give you greater control and will be a much better option.
In terms of rev-range, you want to try to keep it in the MIVEC range, so you want to change gears as late as possible so when it goes into the higher gear the revs don't drop below the MIVEC point.
MIVEC is My Friend :D
- Slither
As with any car, the higher you rev it the more you'll wear it out. Having said that, the FTO was designed to rev that high and has certain protections in place, such as rev-limiters that prevent you from reving too high when the engine is still cold.
Rev-hard and enjoy the MIVEC range, that's what it's there for!
- smorison
- The Godfather
3000??? the stall converter only lets you go to 2500rpm...jonowong wrote:when i launch i put my left foot on the brake and my right foot on the accelerator... but it cant go over 3000rpm to launch and i cant get any type chirps or anything!!!
if you have really grippy tyres you may be bogging down too much on launching... you don't want a huge amount of wheel spin as its doesn't convert into fast acceleration...
