fog light switch not turning off the fog lights
hi guys,
ive got this problem recently where the fog light switch will turn on and off the dash lights fine, but it does not turn off the fog lights. So i am having to drive with the fog light fuse out so that my battery does not drain.
does anyone else have a similar experience?
also this might just be coincidence, but the fig light switch was a bit sticky (not coming out from the on position cleanly) for a while... but now since the fog light problem surfaced, the switch is not sticky anymore.
appreciate any suggestions
Disrespect is easy. Respect is the difficult road to take.
- smorison
- The Godfather
if it was burnt out, would the foggies stay permanently on?smorison wrote:chances are you will find that the relay is burnt out and has to be replaced (its the entire switch)...
the foglight switch is used by Galants and i think lancers now as well so its not that expensive to replace (i've been through 3 of these)
- smorison
- The Godfather
yeah they do... i had that happen a few times... what actually happens is it gets so hot it melts the plastic and disrupts the path of the ballbearings in the switch...G1 wrote:if it was burnt out, would the foggies stay permanently on?smorison wrote:chances are you will find that the relay is burnt out and has to be replaced (its the entire switch)...
i think they are like 30-40... i used to get mine from japan until i found out they were the same price here.
- Beme007
- smorison
- The Godfather
- SchumieFan
- payaya
been through all this! I've been through two fog light switches take it apart, and i bet you the back of the switch is melted!
Its becuase the relay in actually behind the fog swtich and the relay isnt able to take the long hours they are turned on for.
I acutally bypassed the swtich hooked up a second switch with its own relays and stuff.
kempys in NZ have heaps. 60 bucks from what i remember.
