MIVEC not working
MIVEC not working
Hello,
Sorry but I thought I'll raise it up here again as I realised there were some people with this problem but don't seem to have any resolutions apart from going in to north shore mitsi...but don't really want them to take the car without my self really knowing what is going on here.
There are no warning lights for me and the mivec just doesn't come on.
When I rev it in gear the small cam just continues past the 5krpm and keeps going with the small cam....there are no rush of air sound either....
Any ideas?
Or any one with this problem got it solved?
Thank you,
Any ideas?
Thank you,
Well last I tried really reving it was before the mivec went out completely.
In first gear, I reved till about 6krpm and it started to bounce....which never happened before, then ever since I didn't get mivec completely.
After that I have tried to rev it up to about 5500rpm and maybe even close to 6krpm and still no mivec.
Before it was coming in and going kind of thing and then from one day short after it just stopped working....
Don't know what the problem is....
![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
Sounds like the problem I had with mine a month ago. The Mivec just failed to engage one day and never came back. I could rev to around 6500rpm in any gear then the limiter would kick in. I did however get the detonation sensor warning light from a diagnostic check come up. Sure enough the problem was exactly that. Had the faulty knock or detonation sensor replaced and Mivec was back as good as new. If this is your problem be aware that the sensor is literally buried into the middle of the block of the engine and labour is very intensive for a relatively cheap part.
Hope that helps...
Hope that helps...
- RichardH
Try the diagnostics test for getting out engine ECU codes...
http://www.ftowa.com/html/workshop/workshopart07.html
Let us know what magic number comes out!
- Rich
- Rich
- RichardH
Great.
So just so that I don't damage anything...
I just open up underneath the steering column and get any copper wire and plug it in to the bottom last right hand side pin and connect it to any metal part of the body to earth it and I should get these blinkings?
Thank you,
I will try this very soon.
![Wink :wink:](./images/smilies/icon_wink.gif)
Thank you,
Ok,
I have tried what Richard had told me to do....
And I get nothing....
I get the no code signal.....that is signals every second constantly....
So I guess that means none of the sensors are wrong....
So what is the problem then?
Also, I have a drive of it again last night and I could feel the mivec coming in, but it's so weak that you can hardly notice it!
However, before it really didn't work at all!
But now, it does come in, but it's so weak!
What's going on????
I might try and get some ideas here on the forum until Wednesday, and if I still don't know what's wrong, then I'm taking it to Northshore Mitsi..
But it'll be great if some one here has any idea...
Thank you,
What's going on????
Thank you,
- csvperformance
Same Problem
My mum (im 15) has just recently bought a FTO GPX and I was wondering whether it was normal or common to rev limit a 6.5k RPM? it only occasionaly does it though. Could it be because it is cold? Will it show a signal if there is something wrong thanx
P.S If you have any answers send me a message please.[/b]
- Boris
Ok, hold on, i think your problem isn't quite similar, this thread is about MIVEC not kicking in, I think your problem if I understand it correctly is that you car hits the 6.5k and a limiter kicks in, now this could happen for a number of reasons.
1: You are not warming your car enough, tell your mum to take it easy.. gee... the fto has a default limiter at 6.5k when the car is still cold. Most people here normally give the car 15mins before the engine even seeing the 5k mark... remeber an fto isn't like a falcon, *8k rpm is quite high, the car has to be completely warmed up, before you redline it.
2: One of the critical sensors could be malfunctioning, cos normaly if one critical sensor goes, then the limiter at 6.5k kicks in.
There are a few threads already out there about this topic, but I though I would just give u a brief summary. Hope this helps, and welcome to the club btw.![Smile :)](./images/smilies/icon_smile.gif)
- csvperformance
Thanx
Thanx for that, It ain't too bad of a ride. We took a R33 Gts-T for a spin but it didn't turn as many heads ![Smile :)](./images/smilies/icon_smile.gif)
Ok guys, sorry about the delay in reply.
I found out what the problem was.
My clutch was worn out so when it got to the mivec range it slipped so bad that the mivec was kicking in but you just couldn't feel it!
That's all.
However, now I have a different problem....well not completely.
After changing the clutch, as this seems to be the only problem I went for a ride and it's been couple of weeks at least since I changed the clutch, the mivec seems to be very weak compared to what I used to have.
I can definately feel it now, but it just isn't as strong as before.
Before I could hear the air roaring in...now it's more subtle!
But you can still hear it but not as loud!
Any ideas?
Thanks guys for the advice, much appreciated!
That's all.
Any ideas?
