Just double checking what we will both need to do this conversion - so far we have
ECU, harness, sensors, hubs, cluster, booster. Is there anything else involved? Will this make it a 'plug and play' application?
His dads car will have the ECU, harness, sensors hubs and cluster, and i will have the same off the GPR.
The only thing were not sure of is the LSD that was in my car. Will this affect the hub/bearing because of the stubbier shaft? or is this only at the gearbox end, and will a same spline shaft fit straight in? Ill grab his shafts to fit into his hubs and put them on the mrs car. he will take my ABS gear.
(by the way reason why were 'swapping' is mine is auto his is manual)
Have we missed anything?
*waits for all the cynics complaining too much work for nothing etc*
