Gearbox oil leal
ftonoob
Gearbox oil leal
Post by ftonoob »
Noticed my gearbox is leaking oil at both axles. How to fix?
fraz91
Hair-do
Re: Gearbox oil leal
Post by fraz91 »
ftonoob wrote:Noticed my gearbox is leaking oil at both axles. How to fix?
Degrease it first and confirm it's the CV-input shaft seals. If so, then you'll need to remove the CV's and replace the inner seals. They're cheap from memory, but a pain in the ass to get the inner CV cups out.
Pop the shafts & replace the seals.
http://www.amayama.com/search/?q=MD755526
You could probably source the seals locally, there's nothing special about them, they're a standard type size seal. Any bearing shop can match up.
ftonoob
Post by ftonoob »
Are these just a pry and replace?
ftonoob
Post by ftonoob »
Do I have to replace axles also?
ftonoob
Re: Gearbox oil leak
Post by ftonoob »
Problem solved new seals installed. Getting axles out was a pain and honestly wasn't expecting so oil to leak out.
