Broken studs
Broken studs
Looked in my engine bay and saw the studs connecting the driver's side mount to the bracket on the engine were broken. Can I drill and replace?
Re: Broken studs
Yeah.. you probably could. Plenty of steel in that.ftonoob wrote:Looked in my engine bay and saw the studs connecting the driver's side mount to the bracket on the engine were broken. Can I drill and replace?
Could try using an Ez-Out to wind the broken studs out
- fraz91
- Hair-do
Re: Broken studs
Just don't buy cheap ones, they breakBennoz wrote:Yeah.. you probably could. Plenty of steel in that.ftonoob wrote:Looked in my engine bay and saw the studs connecting the driver's side mount to the bracket on the engine were broken. Can I drill and replace?
Could try using an Ez-Out to wind the broken studs out![]()
Re: Broken studs
Even expensive ones aren't hard to break
Re: Broken studs
Bennoz wrote:Even expensive ones aren't hard to break
- fraz91
- Hair-do
Re: Broken studs
Why are you worried? You'll be able to twist the broken studs out with your pinkySahin wrote:Bennoz wrote:Even expensive ones aren't hard to break
Re: Broken studs
I will have a bracket?? Would it not be easier/quicker/cheaper/better to replace the bracket?
Re: Broken studs
He's saying the studs connected to the bracket are broken, not the bracket itself.Taz wrote:I will have a bracket?? Would it not be easier/quicker/cheaper/better to replace the bracket?
Re: Broken studs
yes - but replacing the bracket and mount will fix this problem without f**king around or drilling etc
Re: Broken studs
Yes - but he's not in AustraliaTaz wrote:yes - but replacing the bracket and mount will fix this problem without f**king around or drilling etc
Re: Broken studs
This ^^yes - but replacing the bracket and mount will fix this problem without f**king around or drilling etc
- Storm
Re: Broken studs
Get another bracket, I've yet to see someone without a lot of experience successfully get a stud out using a set of those things
Re: Broken studs
Well one studs out. WD40 penetrant thank you. Getting a bracket not so easy. If was an sr20 or rb I wouldn't even be typing right now.
Re: Broken studs
Ive got a few of those brackets.They arent that hard to come by
Re: Broken studs
As has been said before, he isn't in Australia.
Re: Broken studs
Well studs replaced and back on the road. Extractor kit worked like a charm. Thanks guys.
