This car is no longer for sale complete. It will be dismantled and sold off as individual parts from tomorrow.
So some details on the car;
Model: 1995 FTO GPX (race only import).
CAMS Log Book Category 2 – Production SportsCars 2B
Engine and engine modifications;
6A12 Mivec 2.0lt V6.
Modified cold air intake with K&N pod filter.
Oil filter relocation kit with front mounted engine oil cooler.
Extractors with side exit exhaust and Lukey Sports muffler - no CAT.
Davies Craig EWP80 electric water pump with in dash amp meter.
NGK Iriway 9 Iridium Spark Plugs.
Custom 2lt oil catch can.
Gearbox & Differential;
5sp Manual FWD with Cusco LSD and 4.625:1 gears.
Suspension modifications;
Tein Type HA Coilovers with adjustable front camber tops.
Cusco alloy front strut bar and adjustable alloy rear strut bar.
GPvR 20mm front sway bar with polyurethane bushes.
Modified GPX front control arms with brackets for GPvR front droplinks.
Polyurethane front control arm bushes - front and brand new rears.
GPX 18mm rear sway bar with polyurethane bushes.
Megan Racing adjustable rear camber and toe control arms.
Polyurethane rear trailing arm front bush.
ECU & Electronics;
Factory GPX ECU.
Battery relocation to rear of passenger seat.
Razo Dual Stage Shift Light.
Brakes and brake modifications;
1" Brake Master Cylinder inc master cylinder brace.
Brembo Sport slotted front brake rotors.
Project Mu H16-03 front brake pads with titanium backing plates.
Ferodo Racing DS3000 rear brake pads.
HEL Braided brake lines front and rear.
Other Modifications;
Facelift front bar with custom brake ducting and cold air intake feed.
GPX passenger seat and seat rails including 4 point harness.
Sparco Pro 2000 race seat mounted with Bride adjustable seat rails.
Sparco 6 point race harness with CAMS expiry 2018 (for non International events).
Note: Harness is new, was purchased & unused for 4 years by previous owner.
CAMS approved 6 point roll cage by Bond Roll Bars including side intrusion bars.
CAMS approved kill switch, tow hooks, bonnet pins and window net.
Functioning factory power windows, power mirrors & door locks.
Functioning factory dash - Tacho, Speedo, Water Temp & Fuel.
Razo non slip pedals.
Foam filled (ethanol compatible) fuel tank with custom fitted drain plug.
Alloy rear wing.
GoPro camera mounts - front bumper, rear bumper & facing passenger seat.
Wheels and Tyres;
Speedy Holotype-R 17x7+38 5 Spoke Alloy Rims.
Dunlop 215/45-17 Race Slicks - used but still OK to race.
IMPORTANT: The following items previously advertised are no longer included. These items have been sold separately.
65mm throttle body with modified intake plenum.
Mitsubishi factory 210cc Injectors.
Custom parallel fuel rail feed with Malpassi type fuel pressure regulator & VDO fuel pressure guage.
eManage Ultimate piggyback ECU.
Innovate LC1 wideband O2 sensor including guage.
The engine is being restored to factory ecu, factory fpr, factory injectors etc.
And some pics
And some videos
Note: Additional more recent videos will be put up over the next couple of weeks.
http://www.youtube.com/watch?v=auOoMIiigm8
http://www.youtube.com/watch?v=wfIZPXCIvK8
Wakefield Park
[VIDEO]http://www.youtube.com/watch?v=aiLjvAqvcss[/VIDEO]
Eastern Creek
[VIDEO]http://www.youtube.com/watch?v=auOoMIiigm8[/VIDEO]
Mt Panorama, Bathurst
[VIDEO]http://www.youtube.com/watch?v=wfIZPXCIvK8[/VIDEO]
