A bit about the car:
- 1995
Mitsubishi FTO GPX
175,000km
Black
Semi-Automatic
- Stereo surround has cracked on the passenger side and as a result, is missing a small section
Some scratches around the place on the outside
Small tear on the drivers seat and the floor on drivers side
- Rocker cover gasket leak, possibly from front seal's
Water pump leaking
Drivers belt cracked
Leaking sump, plug stripped
Would be good to put a bit of work in to, or for parts.
Definitely can't hold on to it, so I will basically take the best offer I get for it.
Vehicle is located in Canberra. Feel free to PM me any questions, or ring me on 0410 210 720. If I don't answer then just leave me a message or send me a text and I'll get back to you.
