Upgrade Spark Plugs?
Hello,
Just wondering what type of spark plugs every one has upgraded to, if you have upgraded them.
I'm getting a funny business when trying to find some that are NGK, but not getting a positive feed back form people so not so sure.
What brand do you use and where did you get them from?
Thank you,
Thank you,
- Boris
Ye, good question.. and part numbers would be great, cos this is an upcoming job for me too...
Still semi-on topic, sorry, jst ignore it if this is bothersome, don't want to be hijacking this thread, but it reminded me of a question i had in mind.
Is it worth, modifying your spark plug fitting to move the spark plug closer into the cylinder & and to the piston, or is this simply done by buying a longer spark plug, I read somewhere that this could give you a difference, because more fuel is burnt i guess...
- smorison
- The Godfather
Boris wrote:Is it worth, modifying your spark plug fitting to move the spark plug closer into the cylinder & and to the piston, or is this simply done by buying a longer spark plug, I read somewhere that this could give you a difference, because more fuel is burnt i guess...
i would say what they meant is it gives a smoother burn and a faster burn... probably doesn't burn any more fuel seeing as your cars run pretty close to perfect AF ratio's...
if you can make the A/F ignite faster and hotter you will get more power.
- dannyboyau
Mate i am with paladin on thisBoris wrote: Is it worth, modifying your spark plug fitting to move the spark plug closer into the cylinder & and to the piston, or is this simply done by buying a longer spark plug, I read somewhere that this could give you a difference, because more fuel is burnt i guess...
I strongly recommend against this as you could easily punch a hole in the top of your piston if you use the wrong size plug.
