inlet manifold
NextLevel
inlet manifold
Post by NextLevel »
does anyone have a help guide on "how to removing the inlet manifold?"
and also, how long does it take to remove.
cheers
Re: inlet manifold
Undo all the bolts and lines? make sure you dont lose any!
and as fast as you can undo the bolts lol
Re: inlet manifold
Don't forget to undo the bolts around the back too, if you don't it wont come off ;)
Unbolt the throttle body and let it hang, don't need to undo cables/hoses, then bolt it back on when intake is back in place.
Unplug the sensor harness's on the drivers side of the intake and leave the sensors attatched to the intake.
Take your time, don't drop any bolts/nuts/washers into the lower intake pipes, put a rag over the lower intake pipes when the upper intake is removed, check down all the intake pipes with a torch before you put it back together just to make sure there is nothing foreign down there.
Should take you an hour on your first go, 20 min when you have done it a few times.
Good Luck :D
Re: inlet manifold
Last time I did it I wanted to see how fast I could remove the manifold.
14 minutes and 47 seconds :cheers:
Wasn't rushing it much either. Could probably get it done in 12. :lol:
Re: inlet manifold
Vectose wrote:Last time I did it I wanted to see how fast I could her to.....
14 minutes and 47 seconds :cheers: :lol:
Re: inlet manifold
Here we go, another pissing contest. :lol:
I can do it in 3 min flat with an angle grinder. :P
Sahin can just rip it off with his bare hands without undoing anything, 18 seconds.
Re: inlet manifold
:lol: I like to have fun when I work.
Re: inlet manifold
PHIL069 wrote:Here we go, another pissing contest. :lol:
i dont even raise the bonnet... just straight thru the c**t
Re: inlet manifold
Better airflow straight into the intake.
Re: inlet manifold
Took me what.. an hour and a half to get it off at your tappet day Phil? Something like that? :lol:
But yeah just remember where stuff goes and dont drop anything :lol:
Re: inlet manifold
Take a couple of pics as you go for reinstalling reference. :idea:
NextLevel
Re: inlet manifold
Post by NextLevel »
you guys crack me up :lol:
thanks for the tech tips fellas.
