engin upgrade
viper-99
engin upgrade
Post by viper-99 »
i want to switch out my 6a12 for something different dose any one know of any engines apart from the 6a13 and lancer engines that will fit also being a Mitsubishi is it possible to fit a vrx all wheel drive set on to a fto
Re: engin upgrade
viper-99 wrote:i want to switch out my 6a12 for something different dose any one know of any engines apart from the 6a13 and lancer engines that will fit also being a Mitsubishi is it possible to fit a vrx all wheel drive set on to a fto
Anything is possible with time and money.
The AWD conversion is doable with bits from I believe an Evo 3 or 4 (pretty sure the 3) but its a massive job and I dont think it has been done very many times. Doable, but a rare and difficult job. $$$ and time needed.
As for engines, 6A13s and Lancers donks are the easiest to do. You could also turbo the 6A12 ;)
Re: engin upgrade
ENGIN!!!
Retsub
Re: engin upgrade
Post by Retsub »
Trollop
4. 02 Prado V6 (Wife's Car)
Re: engin upgrade
What is a vrx all wheel drive set?
Re: engin upgrade
silverGPX wrote:What is a vrx all wheel drive set?
Isnt the VRX Magna all wheel drive or at least AWD optional?
Re: engin upgrade
You only said that cos you googled VRX All Wheel Drive Set
:geny:
Re: engin upgrade
God my avatar is sexy
Re: engin upgrade
:geny:
Actually... no I didnt. Obviously the only lancer thats AWD is the evo, galants/legnums arent VRX as far as I know and its obviously not out of a mirage. Couldnt think of anything else apart from a magna that would fit.
While I did have to google it to check, I worked out for myself that it could've been a Magna :mrgreen:
I googled "Magna VRX AWD" :D
Re: engin upgrade
no
Re: engin upgrade
Sahin wrote:no
Re: engin upgrade
Just put a viper engin in it bro
Re: engin upgrade
Should bolt straight up!
Re: engin upgrade
4G63 is the way to go in my opinion.
Though for simplicity and/or cost there are other great options too
viper-99
Re: engin upgrade
Post by viper-99 »
well how far can i bore and stroke a 6a13
Re: engin upgrade
viper-99 wrote:well how far can i bore and stroke a 6a13
You can't
Re: engin upgrade
Why would you want to bore and stroke a 6A13 engine?
Re: engin upgrade
As far as I can recall the 6A13 has been taken as far as it can go.
Re: engin upgrade
The same reason you'd do it to any engine :D
Re: engin upgrade
There have been some which were resleeved and bored to 2.7L or so, but considering the car is FWD and from what it seems the crank is only good to about 600hp, spending money on a capacity increase is pointless.
To be honest, 300-350hp is about as much as you can "use" in a FWD car, and this is in the higher gears as it is
