Manual gearbox reconditioning
- JOA81
Hey was just wondering where I can get my manual gearbox reconditioned I know bennoz does them but I'm in qld unless I can send it down to him
Re: Manual gearbox reconditioning
its not that expensive to ship a gearbox man, problem is that bennoz is a busy married man! lol
- JOA81
Lol true
Well if I can find a place up here in qld that would better but if not I might have to send it to some where else as long it's good
- Supplanter
- Connor_1994
^^^^LOL^^^^
- spetz
Supplanter wrote:Bennoz loves the trannies.
Bahahahaha
- Kustom
Have you tried giving a gearbox/diff shops around brisbane a call & asking for a quote?
- JOA81
yeah was probably going to do that this week just wanted to see if there was one that someone had used before, that way I can trust they can do an FTO box
Just order all the parts and go here you go put it all in.
Isnt it some US cobra transmissions website.
- JOA81
yeah I got a link to them from bennoz awhile ago but haven't had the courage to do it myself so haven't ordered them
If you acquire the parts then drop it off at transmission place itd b heaps cheaper
That's right, plus the kit has dropped to a hundred bucks now, cheap as chips.
http://cobratransmission.com/index.php? ... d=50089001
- spetz
If doing an actual recondition of the gearbox wouldn't new synchros be used, otherwise what's the point?
You can buy them from there also..
Because the bearings wear out well before the syncros. You only replace syncros if you need to - the full kit with syncros is f*cking expensive too, about $500. Brass aint cheap.spetz wrote:If doing an actual recondition of the gearbox wouldn't new synchros be used, otherwise what's the point?
When you next get one can you get 2?Bennoz wrote:That's right, plus the kit has dropped to a hundred bucks now, cheap as chips.
I was thinking of buying the bearing kit but that means id have to take my gearbox out again, it was hard enough last time.
Coz i wasn't helping you.. and just had a look.. the whole kit with syncro's is only $389 bennozsilverGPX wrote:I was thinking of buying the bearing kit but that means id have to take my gearbox out again, it was hard enough last time.
Another thing i did for you for nothing and not even a thankyou at the endsilverGPX wrote:I was thinking of buying the bearing kit but that means id have to take my gearbox out again, it was hard enough last time.
Just ring around and get a few quotes or send it down to bennoz when he has the time
