HELP engine oil leaking!!!
- looii
Mah engine oil is leaking and it isn't the gasket thats its leaking from. It appears somehow leaking from the engine itself. I brought it in the garage to see what they can do, the bloke just told me to wait until my car reaches 100,000kms (thats like another 40,000 kms to go) and he'll fix up everything. He told me not to worry about it... But i am, as i am a worry wart. Im just wondering if any other fto's (1995 gpx) are having the same problem and what did you do rectify it??
Sound to me like the camseals are leaking. I had this problem when I got the car, but got it fixed for nothing under the dealer warranty
It is apparently nothing to worry about, but like yourself, I was not happy that it was doing it. Also, if it came time to register the car, it may get knocked back because of it. It depends on how anal the guy checking it is.
I would question the how authentic the 60k is on your car, as I wouldn't expect the seals to leak so soon. But the leaking may be related more to age than km's.
The cost, if you do it now, would be around the 1000 to 1500 mark I would expect. Very time consuming job. If you could wait until the major service, it is little extra cost (as that costs a packet anyhow).
No way of knowing for sure. But look at things like wear on the seats, wear on the carpet (especially around the pedals) and just a general feel of the condition of the car (eg rattles etc). It depends on what cars you have owned or spent some time in before, but you just get a feel for whether a car has been driven for more than what it says.
When we were looking for our FTO (not long ago), we went from the one we bought (84k km's) to one with a "genuine" 50k, and the difference was huge. The carpets were worn, it was full of rattles and the steering wheel was quite well "used".
But, if you are happy with your car (except the leaks, of course) then that is all that matters. Best of luck and enjoy!
- smorison
- The Godfather
- MADFTO
- bozhu001
My engine was leaking big time before, and most mechanic thought it was the head gasket, until when the repairer actually opened up the engine....
phew lucky it was just the engine seals thats worn.
so the cost is around $1000 to get it fixed.
now my car does not leak at all. 70K KM and drives like new
- smorison
- The Godfather
unique have done a few now... it is normally best to do it as part of a major serivce (if you are getting close to 100k say anything over 85k and its really worth doing).
depends on what is wrong but anywhere between 1000-1500 to fix it is in the ballpark (and have the top of your engine cleaned and put back together properly)...
- payaya
thats what i reckon! Ive always used a 10W40-40 never an oil leak. I suspect its the buys using the thin 0-5W30-40 stuff.MADFTO wrote:*smiles* mine hasn't leaked oil yet =) *touch wood* =)
Most oil leaks would be caused by having too much oil in the system I suspect + general wear and tear =)
I've never had an oil leak, but the number of times I've had battery acid leaks . . . *grrrr*
Maybe I should tone down the cornering =P
- payaya
same i replace me battery more often then i should.MADFTO wrote:*smiles* mine hasn't leaked oil yet =) *touch wood* =)
You know MADFTO, vibration is a big killer in batteries, and my FTO is so stiff no wonder i always have to change the battery.
- smorison
- The Godfather
- Boris
i had oil leaking out of my rocker cover gaskets for ages...ever since i had the car...
i changed my rocker cover gaskets and my cam seals and i dont have the problem anymore. I dont even think i needed to change the rocker cover gaskets...just put a bit of sealant on and it wouldve been fine i reckon...
simon
simon
i bought them from northshore mitsu for $54 each and replaced them myself
so... about $110 for parts and a couple of hours work
simon
simon
- smorison
- The Godfather
