Clutch soft and hard to put into gear when cold
- den0va
As the title... I've checked the clutch fluid level it's over max. So am I right to say that my slave cylinder shiet itself?
Re: Clutch soft and hard to put into gear when cold
it may be the clutch master cylinder seal, under pressure it could be releasing fluid up the bore.
4. 02 Prado V6 (Wife's Car)
- den0va
hmm... but I don't notice any major leakage?
Errr.... why is this posted in the forum help section?
This section is only for problems you are having with the site or your account.
- den0va
Wtf? I have no idea... I swear I posted in the FTO help sectionVectose wrote:Errr.... why is this posted in the forum help section?
- aza013
- NSW Coordinator
you're the man aza
- den0va
aza013 wrote:Fixed.
Yes he is haha... I guess I'll have a better look tomorrow and if there is no noticeable fluid leakage I'll bleed it, if the problem still persists then it's either one of the cylinders leaking.Sahin wrote:you're the man aza
- vipfto
this ^silverGPX wrote:bleed it
prob have air in system, if your not actually leaking fluid otherwise master or slave seal gone
- den0va
Cleaned the reservoir of dirt and filth, bled the system and all seems A-OK now! The fluid that came out of it was so filthy it looked dark green/black in colour lol... pedal feeling WAY better like when I first got my car best couple bucks I've spent on my car yet haha
