this guy done it, but only added 75bhp would it f**k the motor? from the comments his motor had had no problems?
http://www.youtube.com/watch?v=M_UZxxLFQqE
running noz in stock motor!
adzski
Re: running noz in stock motor!
adzski
well i guess my prior assumption about noz was correct.
- aza013
- NSW Coordinator
Ben was running it for some time 100 shot
viewtopic.php?f=22&t=13666&start=40
Just make sure your dickhead mechanic doesn't low rpm, load up the car on a dyno & hit the button too early
That aside, it went hard. 100 shot runs out pretty quick though, I was using a bottle every 10 laps at Oran Park, that's a $130 refill...
On the street, after the initial 'testing' period, I'd use a bottle a month on average.
- ZFL45H1
How often in the month did u use it bennoz
Car top out at 140mph this morning?
You need a tank, one of the big ones.
You know what, make it 2.
And you need it by tonight right?
Ammetuers don't use nitrous oxide, I've seen the way you drive you've got a heavy foot!
- phunkydude
Real NOZ spits fire from your exhaust...
True story, from FnF/2F2F..
