I've messaged the eBay seller of the CV joint.
http://www.ebay.com.au/itm/Mitsubishi-F ... 0b7&_uhb=1
I asked if he sold the ABS version.
His response was;
"Hi there,You can remove your ABS ring and put on the non ABS joint.
Cheers Duza"
Is this correct?
Outer CV Joint.
- Shhtuart
Re: Outer CV Joint.
Just get one of these
http://www.camskill.co.uk/m3b0s12p3588/ ... d_DE2A_1_8
Alternatively you can give this one a go - all you would theoretically have to do is put your old ABS ring on the new joint if its the right one.
However the camskill one is almost the same price and comes with a new ABS ring.
- Shhtuart
Re: Outer CV Joint.
That one works out to be $53AUD BEFORE shipping. They are a bit heavy too so it won't be cheap.Taz wrote:Just get one of these
Re: Outer CV Joint.
Well its either take the gamble, or pay an extra 20-30 dollars
Keep in mind Camskill also comes with a new ABS ring as well.
Just make sure it has the correct fitting for an ABS ring if you take the gamble.
Re: Outer CV Joint.
Yeah, I've swapped a few ABS rings. And in reverse, bought one from Sydney Driveshaft & had to knock the ring off (no pun.)
- fraz91
- Hair-do
Re: Outer CV Joint.
just have to be very careful when swapping the ABS rings as they're quite fragile. Make sure you tap it off and on evenly otherwise it will snap. Learnt that the hard way
- Shhtuart
Re: Outer CV Joint.
Thanks for your input guys. I'll buy it from eBay and be very careful when changing the ring over
- payaya
Re: Outer CV Joint.
sh*t looks like the sellers english has gotten better! You can get them from drive shaft places for $50. They are off the shelf items.
