Info From Mitsubishi
- Black_FTOGPX
I have contacted the person at Mitsubishi who was in charge of rolling out the FTO. I asked him if he knew of any ways we could increase the performance of the 6A12 engine. And also if there were any power sacrifices made to comply with emission laws.
He has also given me some history on the FTO
See his reply below.
Hi Joel-san,
I contacted with a person who handled the FTO V6 before, to confirm if
there were any sacrifices to meet the Japan emission regulation
requirement.
The 6A12 MIVEC emission control system is almost 100% depend on the
performance of catalytic convertor.
The compression ratio of engine was increased to perform 200PS output
designed with the premise of 100 octane premium fuel.
The EGR does not actually spoil the engine output performance.
The air flow sensor system was chosen the D-jetro type to reduce the intake system air flow resistance.
Only one thing could spoil the engine performance of 6A12 MIVEC is the
exhaust system air flow resistance, caused by catalytic convertor.
Additionally, I put on the small history of GPX version R evaluation:
We originally planed to beat the Integral Type-R with performance and
maneuverability.
This means, I ordered to increase the engine out-put of 6A12 MIVEC also.
But, engineer's comment was negative. He also commented that the only one
way to
increase the engine output was engine displacement volume increase.
So, I changed the plan of GPX version R, only revise the handling
characteristics
as a Gymkhana special machine, with a specially tuned helical LSD and
harder suspension.
Hi Joel-san,
requirement.
maneuverability.
way to
characteristics
harder suspension.
- FTO338
Dam does that mean all those mod we did are down the drain
Hmmmm u wouldn't happen to know what size cat that will do the trick?
Good Job Black_FTOGPX
really great info there! and coming from a good source 2!!
So i guess then my hi flow Cat is helping me some!
Hope its not doing harm though...
oh and hnm738 when u increase the engine discplacement vol it means going up from a 2.0L to a 2.3L or 3.0L (ussualy achieved by boring of the engine- cylinders etc)
- MADFTO
*smiles*
You must remember, back when the FTO was initially designed, 8k rpm was very high.
even in 95 when I'm guessing the version R specifications where being debated, FTO had only been in production a few years and they didn't want to modify the engine production line for a small volume release.
Anyways, you have to remember economies of scale comes into play with limited release models.
I'm surprised they didn't produce a tuned length set of headers though, I guess they took the engineers advice and didn't look into it at all.
A pity =)
A pity =)
hey hnm738!
Well.... there has been some speculation that hi-flow cats give minimal power gains and the link between "reduced back pressure" has also poped up.
But i think that is to do more with Turbo cars and not as a big issue in N/A cars.
Either way i love it and ain't taking mine off!
- Slither
actually reduced back pressure is something that effects n/a cars, basically its good to allow your car to breath better but if u go too far u loose back pressure and its detremental to your power, turbo cars u basically want to loose as much back pressure as possible!! thats why u shouldnt get too big an exhaust on a n/a car where as the bigger the better in turbo's!!
well thats my understanding of it anyway, i could b wrong!!!
Hey ethan! what up!
u could be right there mate bout turbos, My bad.
I thought i read somewhere that High back pressure could cause loss of engine power and economy and also cause overheating
But i guess ud to have a MASSIVE exhaust and to actually fell the reduction difference..
I guess its like everything else in tunning - the idea is to find the happy medium
- smorison
- The Godfather
- Slither
- FTored
i think there is a kit from mitsu that makes the diplacement bigger.It makes it 2.2 L. that is what is used in Moritakus Fto. The one with 550hp mivec+turbo. Btw Hi to all.MADFTO Posted: Thu Jul 08, 2004 10:14 am Post subject:
*smiles*
A pity =)
Thi was tkan from Ftooc:
Patt wrote:
Right Mitsi have parts as standard for two re-bores as I discovered when doing my re-build. IIRC the largest took it to 2.3 - but don't quote me on that! and I didn't look any farther as I needed the engine back in the car asap plus couldn't even bring myself to look at the costs of the pistons etc.!
- Black_FTOGPX
I have asked My contact about this.
Looks like they do supply over sized pistons and rings.
I am waiting on the part numbers for these so we can price them up.
Here is his reply
A engineer handled the 6A1 commented that the limit of bore size increase
potential of 6A12 may
up to 2mm in diameter.
He also commented that MMC supply 1mm over-sized piston to match the
overhauled engine block.
So, if you could purchase the over-sized pistons, the capacity might
increase in 50cc, with
1mm bore size increased block. The piston rings to fit the 1mm over-sized
piston are also exist.
Here is his reply
From the Mitsubishi CAPS CD
MIVEC engine Pistons
STD SIZE P/N MD316711
O/SIZE 0.50 P/N MD323689
O/SIZE 1.00 P/N MD323690
non-MIVEC engine Pistons
STD SIZE P/N MD316698
O/SIZE 0.50 P/N MD323676
O/SIZE 1.00 P/N MD323677
With a bore of 78.4mm and a stroke of 69.0mm, the std engine size is 1998cc.
I'm guessing that the oversized pistons increase the radius by 0.5mm (1mm diameter) and 1.0mm (2mm diameter). This means that they would increase the capacity to 2049cc and 2101cc respectively. If my maths are correct
Brian
Brian
- Black_FTOGPX
- MADFTO
That's bascially it I believe, well you need to do the block and the head. Since you're not changing the stroke at all, you just need to bore out the cylinders to allow the pistons to fit.
Mind you, you're probably want to remap the fuel mappings to compensate a little, but with such a small change in each cylinder, I'd think the ECU would compenstate for the extra air you're pulling in automatically.
I'm assuming all the other aspects of the pistons stay the same, only the diameter of the piston head is increased.
- smorison
- The Godfather
- wildfaye
Ic, so the block looks the same...onli internals bored with bigger pistons.
100cc equates to 10-15% more power, requires bigger injectors and fuel pump, mabe a upgrade ecu...
at the same time while boring the engine, could also port n polish the entire intake and exhaust...
does tis sound alrite from a tech dummy like me?
