Smoke from starter motor
Does it mean that the starter itself is fucked or does it mean that the wiring is fucked? Will be replacing it regardless when the new one comes from dwayne but just thought I'd ask just so I know what to look for.
Re: Smoke from starter motor
PHIL069 wrote:
Zender wrote:all down to the starter motor it let the smoke out pulled it out now to get it rebiult
jamie
Getting new smoke put in then ;)
Electrical components don't work too well without their smoke.
PHIL069 wrote:
jamie
Yeah I read that and it just made me more confused :lol:
Daniel2019 wrote:
PHIL069 wrote:
jamie
Well.....Your starter motor let all it's smoke out and now doesn't work, so just get more smoke put in it :lol:
PHIL069 wrote:
Daniel2019 wrote:
PHIL069 wrote:
jamie
:facepalm2:
Also theres a bunch of oil and grease and sh*t all around it. Would it be OK to degrease the f**k out of it and then try and turn it over or should I just wait until I take it out to clean it up then put the new one in?
You can "degrease the f**k out of it" anyway so you have a cleaner part to remove.
There is no use in trying to start it again, you have already let the smoke out. ;)
PHIL069 wrote:You can "degrease the f**k out of it" anyway so you have a cleaner part to remove.
It starts when tapped a few times with a hammer while the key is being turned.
Not for much longer I reckon. If your solonoid fuses itself together it will get extremely hot, pump out the rest of it's smoke and drain your battery as quick as my FTO is on a dyno :lol:
How long till you get a replacement with all it's smoke still inside?
Could the solenoid fusing together be the result of that rocker cover leak from before with oil falling onto the starter motor or just age/use?
just age + use, they don't last forever. And the solonoid is sealed so the oil couldn't have entered inside.
I saw that massive post that you just edited :lol:
Right, will change over to the new starter when it is delivered in the next day or two.
Cheers phil!
I mis-read your post at first :lol:
PHIL069 wrote:just age + use, they don't last forever. And the solonoid is sealed so the oil couldn't have entered inside.
That was what I was asking :lol:
Didnt know if oil could have reached the solenoid or not. Not that it really matters because the leak has been fixed, was more just for my own learning and curiosity.
Doesn't matter if you have a leak or not, oil will always drip onto the starter when changing your oil filter.
Don't worry Daniel, you turned 18 didn't you? Go to Coles, pick up a pack of 20's. Marlboro Reds have good smoke quality with extra turbons in them which install micro turbo nano cells into your starter motor. Keep smoking the ciggys and blow the smoke inside the starter motor....remember to block the hole out with a finger the whole time to make sure the smoke doesn't come out again. Then put some tape/gluetac and parcel it to Phil's to get it replaced with his starter motor :thumleft:
shadowarrior wrote:Don't worry Daniel, you turned 18 didn't you? Go to Coles, pick up a pack of 20's. Marlboro Reds have good smoke quality with extra turbons in them which install micro turbo nano cells into your starter motor. Keep smoking the ciggys and blow the smoke inside the starter motor....remember to block the hole out with a finger the whole time to make sure the smoke doesn't come out again. Then put some tape/gluetac and parcel it to Phil's to get it replaced with his starter motor :thumleft:
I dont smoke, I like my lungs how they are :lol:
My liver on the other hand...
haha :P good choice mate. Whiskey and Wine is good for health....docs say so! :)
Im more of a whiskey/bourbon and beer man to be honest haha.
This thread turned uber *~delightful!~*.
I don't think I even chuckled.
