gearbox help
Connor_1994
gearbox help
Post by Connor_1994 »
so lately i seem to miss 2nd, 4th and now ive discovered reverse, so all the lower gears, anyone think of a reason why, it happens a lot if i wind the previous gear out but even when i dont it has still done it, and my gear stick feels very sloppy and soft going into those gears,
the guys at work said it may be the selecters? or the cables from gearbox to the gearstick, and to tighten them, anyone know a good way to explain how to do that or any other reasons as to why this could happen :/
thanks guys
Re: gearbox help
i really cbf taking pictures and wiriting a guide.
basically on top of the gearbox you will see 2 cables held in by clips, and then they go into the manual shifter housing and clip into the bottom of the shifter in much the same way. Make sure those are tight. They are easy to get to as ewell if your just tightening them
Re: gearbox help
Re: gearbox help
Read your manual ;)
Re: gearbox help
Selector bracket. Search on this site for it.
den0va
Re: gearbox help
Post by den0va »
I did this not long after I bought my FTO. Mine was welded on because it snapped in a couple places in the joints. http://ftoaustralia.com/v3/viewtopic.php?f=21&t=26348
Step 1: Buy new selector bracket via Dstocks. Part numbers are MR953260, MD748651 or MD749667.
Step 2: Upon receiving the brackets, take out battery, battery tray, bracket for battery tray. Should be able to see it from the top, it's a tight fit but with the right tools you'll be right.
Step 3: Keep the bracket bolted on, now remove the spring clips that hold the cables in place. Those things are little c*nts to remove, I'd use some vice grips or something along those lines. Grip them and slide them up.
Step 4: Once clips are undone, remove cables from the bracket (should just easily slide out) then unbolt the old one.
Step 5: Reverse the steps and it should be all good.
Connor_1994
Re: gearbox help
thanks guys, that was the exact problem, and thanks to my old engine i had a spare engine i had i had another bracket, shes all good now (:
den0va
Re: gearbox help
Post by den0va »
Winning :cheers:
