Changing throttle cable - how easy?
Rob Furniss
Post by Rob Furniss »
How easy/difficult is it to replace the throttle cable and does anyone know what the length is?
I've extended mine for the supercharger (throttle body is further away and round a bend sort of) but it feels a bit gratey even though it's in plastic tubing.
Re: Changing throttle cable - how easy?
Shouldnt bee too difficuly from the throttle body end at all, and shouldnt be too much trouble after that, i assume you would have to take the drivers splash guard off, simply unhook it from the pedal and thread it through the hole.
Easy TB end im sure you done heaps.....
pedal end simple just unhook from pedal throught firewall grommet (easier to remove this too) no need to remove any splash sheild etc???? dont run though there well mine dont anyway ;)
Rob Furniss
Thanks guys
