Can't wait to install these badboys
- den0va
These have been waiting in my garage forever lol... In my possession: KYB Excel G shocks, Lovell Lowered Springs, New Droplinks, Whiteline Strut tower brace both front and rear. Keen to put these on my "boat" . All that I need to buy are new topmounts and new poly bushes, which I am currently on to.
- aza013
- NSW Coordinator
Re: Can't wait to install these badboys
You do know that all this stuff would work better in a car rather than a boat .den0va wrote: Keen to put these on my "boat"
- den0va
- aza013
- NSW Coordinator
No! I did say .
- den0va
Touché, haha nah but in all seriousness my car is a boat at the moment, too much understeer :S
Think I found that foglight switch if youare still looking BTW....
Hey dwayne i dibs your next aircon compressor you get, unless of course you have one in stock, ill grab it probably
- den0va
P.M Sent!dstocks wrote:Think I found that foglight switch if youare still looking BTW....
- spetz
Looking good.
Can you take pics of the front shocks if you get a chance?
And what droplinks are those?
My suggestion is to add an upgraded rear swaybar, and also fit camber pins at the front and add a tiny bit of camber too. If you have good tires by now the car should be on rails.
From the how to change shocks DIY:spetz wrote:Looking good.
- den0va
Vectose has provided photos of shocks. Those droplinks are ones that Ben recommended in a thread I found, $50 for fronts also $50 for the back; both with free postage and handling. All up, $100 for front and rear droplinks. They are made from some third party in Taiwan, can't remember the name but are equivalent to a Mitsu oe replacement. May even be slightly uprated, the quality is awesome.spetz wrote:Looking good.
Bought them off eBay, here's the link: http://www.ebay.com.au/itm/2-FRONT-Sway ... 298wt_1037
And nah I'm going to keep original sway bars and not touch camber; for the same reason I'm not going to buy pillowball top mounts (or even full coilovers), it's a daily driver, not a track car and I would rather just get a decent setup rather than go all out. Wish I had a money tree
- spetz
Are the front shocks the same length as FTO shocks if anyone knows?
As the Lancer ones (which still fit) are longer hence no good for a lowered car
- den0va
Yeah KYB's are the same... Ben had them side by side in the suspension thread or diy changing shocks springs or whatever it is.
- spetz
What about the koni inserts, do they allow the same amount of travel if you know?
- den0va
Sorry, can't help you mate :S have not the slightest clue lol
- ObsidianRadio
I fapped. Just puttin' it out there.
- den0va
Bought new bushings today... Came to a total of around $500 Now just need to track down Top Mounts. Did a calc and so far have spent around $1650 for these parts
den0va wrote:Bought new bushings today... Came to a total of around $500
- den0va
SPF1160 Front Control Arm - Inner Front Bushing ------------------ $58.69
SPF1500 Front Control Arm Lower - Rear Bushing ------------------ $79.76
SPF1344 Front Sway Bar Mount To Chassis Bushing (16k) --------- $22.05
SPF2004 Rear Sway Bar Mount To Chassis Bushing (18k) --------- $26.48
SPF1574K Rear trailing arm ------------------------------------------ $138.41
SPF1573 Rear lower arm inner bush --------------------------------- $174.25
$499.64
$499.64
Again
In total I have spent $800 for my suspension overhaul, that includes Tein pillow ball mounts, KYB shocks, all bushes, drop links, bump stops, dust covers and other little bits and pieces.
