plasma glow dial kit with km/h
Does anyone know if you can buy plasma glow dial kit with km/h instead of m/h? if not are there any similar dial kits?
Re: plasma glow dial kit with km/h
The only difference is the MPH words, I have one in my car, and the locations of the speeds are the same
So the MPH speeds on the outside show the correct speed not the KM/H ones on the inside?
Correct, the inside KM/H ones are useless, they are made for the UK with the conversion chips in them.
so the big 100 at the top is 100KM
you can get a delimeter/mph conversion chip off ebay for about 110 deivered
There is no real need to with this though, as then you have to use the inner ring for your speed...
Is it possible to just get delimiter chips on their own?
You just need to cut a wire from the ECU to delimit it
was more suggesting it for those who want mph - ive thought about it myself actually
Vectose wrote:You just need to cut a wire from the ECU to delimit it
Why would you want that...?Taz wrote:was more suggesting it for those who want mph - ive thought about it myself actually
Not a troll, it's all you need to do.ebmp19 wrote:Vectose wrote:You just need to cut a wire from the ECU to delimit it
My bad, but why would you buy a delimited chip and why doesn't everyone do it?Vectose wrote:
Not many people do it because not many people go past 180km/h. Have a search and you will see that people have done it.
- bjk
- Totes
Except Phil on the dyno.Vectose wrote:Not many people do it because not many people go past 180km/h.
bjk wrote:Except Phil on the dyno.Vectose wrote:Not many people do it because not many people go past 180km/h.
I would still go off the clock with this.Taz wrote:was more suggesting it for those who want mph - ive thought about it myself actually
Aaactually they go to 300kmph if in MPH, so no - youd be 30km off
- payaya
So what is the conversion of amps to engine temp?
