front sway bar
- Connor_1994
front sway bar
so i need a front sway bar, ive looked at ultra and whiteline and it doesnt say they do a front, only a rear, anyone know where i can get front sway bar from
cheers
cheers
Re: front sway bar
Sway bar or strut bar
- Connor_1994
Re: front sway bar
sway bar, the one that goes underneath the car with the subframe and suspension
- phunkydude
Re: front sway bar
spetz would know..
i think he mentioned about whiteline 18mm adjustable front sway bar for fto which he reckon it's suitable for his mirage or lancer.
gpx comes with 16mm stock.
gpvr has a thicker ones but not sure if they're interchangeable.
![Image](http://i.imgur.com/q6n9HFm.gif)
- spetz
Re: front sway bar
I have the Whiteline FTO 20mm front and 22mm rear (both adjustable).
However with Tein SS coilovers and superpro bushes all around the ride became pretty stiff, mostly suited to track use.
Are you thinking of upgrading?
If you haven't done springs/shocks/strut bars first, I would start from there, and only upgrade if there is too much body roll
- ObsidianRadio
Re: front sway bar
sh*t. Sway bars. I forgot about these things!
- ZFL45H1
Re: front sway bar
I've got 22mm both front and rear and coilovers bushes shot but ride really stiff still
love it
Sent from my GT-I9305T using Tapatalk 2
- Connor_1994
Re: front sway bar
ive got good coilivers etc,, my swaybar kinda uh snapped :/ lol
where can i get a front sway bar and bushes and the linkages?
- ZFL45H1
- Connor_1994
Re: front sway bar
i dunno u can see un the metal where its failed and then due to stress the rest of it snapped
- spetz
Re: front sway bar
Why not just replace it with a stock one from someone wrecking an FTO?
You can use a Version R one, but it's a hassle as you need the lower control arms, and all this is quite rare
Re: front sway bar
Signature Swaybars in Taren point have the FTO jig, can do them in whatever size you like, GPX style.
Fulcrum can also do Selbys Swaybars to suit.
Any mob with a spring steel puller can make them from an existing unit.
- Connor_1994
Re: front sway bar
yeah lets not get onto the control arm topic right now hahahaha, mine have issues lol,,
cheers bennoz ill shall give them a call tomorrow and organise one,
and the reason i dont want a used one is theyve been used and had stress put on them and the same thing may happen, so thats why i want a new strong one, i kinda drive my fto a little hard haha
- spetz
Re: front sway bar
Also don't forget that Cusco also make swaybars for the FTO, if you wanted some extra JDMness ![Wink ;)](./images/smilies/icon_wink.gif)
