auto Trans issue
auto Trans issue
My auto gearbox currently won't go into drive or +/- i can move the shifter into D but it won't pick it up it just stays on neutral. So i pulled in apart a bit and found if i pull the transmission cable forward it will then go into Drive. So im guessing i need to tighten the cable but don't know how?
Re: auto Trans issue
This is all I could find. If it doesn't fix your issue you might have a stretched cable that needs replacement.
Thanks Phil thats fixed the issue.
topao wrote:Thanks Phil thats fixed the issue.
Hooray!
*Puts another stamp on my FTO door*
However now i can only start the car whens its in Neutral
- fraz91
- Hair-do
sounds like you've adjusted it a little too far thentopao wrote:However now i can only start the car whens its in Neutral
