Seatbelt Problems
- FTOwnage
Seatbelt Problems
So here's my issue. I have a really slack passenger seatbelt and mum has been hassling me for ages to replace it. I have taken one from my wreck I'm scavenging through. I have let it wind all the way in and now it refuses to unwind.
So my question is can I fix it somehow, or is it gone for good and I need another one? :-/
Re: Seatbelt Problems
You have to hold the seatbelt you took from the wreck completely vertical while you pull the belt out or the seatbelt locking mechanism will kick in
- FTOwnage
So in other words, I've f$&#d it?
- FTOwnage
I have tried doing that from every angle possible. It refuses to budge, so I'm assuming It has seized completely. Getting no movement from it whatsoever.
- kiz
- SA Coordinator
That may be the problem in itself. Is it a wreck from an accident? If so one might assume the seatbelt mechanism is damaged from that?FTOwnage wrote:I have taken one from my wreck I'm scavenging through
1998 Mitsubishi FTO GPVR AERO
- ObsidianRadio
Why don't you just get a brand new belt? They cost a couple hundred but probably worth it if you don't want to get defected and/or injure your passengers...
- FTOwnage
I don't earn a whole lot of money so I've been trying to save and recycle where possible. It worked fine before I removed said seatbelt from the wreck. I just thought it was strange how it wasn't working once it retracted.
Could you perhaps link me somewhere I could find a new/good cond belt?
I'm not cheap. I just earn $350 a week. (KFC slave labour)
Dude listen to me it's probably fine you have to hold it completely vertical to pull the seatbelt out I thought mine were stuffed too
Bolt it into the car and try
- FTOwnage
I'll give it a go tomorrow afternoon. If not I guess a new one is my only option.
ive got a spare i know works if that doesnt
but it should work bud
- ZFL45H1
yeah mate just install it and then try u will never get it level long enough for it to work I've had this problem as weak
Sent from my s3 using Tapatalk 2
- FTOwnage
Sadly, no luck with attaching the belt.
Might need to replace both the belts by the looks of things haha.
For the sake of safety I might just take it too a seatbelt joint and get them both looked at/replaced.
Probably one of those things you'd want to buy brand new anyway mate
- illmotion
I am having the same problem with Taz seatbelt that he just sent me as well D:
Bolt it in!
- FTOwnage
Did you fix yours?FTOwnage wrote:^ +1
- FTOwnage
Affirmative. Pop pulled it open and there was this weird little bit of plastic (not from the housing or seatbelt itself) obstructing the the metal sphere in the side.
- illmotion
