how do i connect the stainless steel led kick plates?
myn arrived today from dstocks i had a look and couldnt find anything to connect them to?
anyones input would be greatly appreciated
- BorepYano
Re: how do i connect the stainless steel led kick plates?
I believe u'll have to piggy back them off the interior lights.
OK, that set have all the proper connectors, so they should just plug in. There will be a plug in front of the fusebox under the dash. When you unplug it, each end will plug into the short lead with the thicker wires that came in the package. It will only fit the one plug, so you should be able to find it. Pretty sure there was a thread a while back with pictures. A bit of a search should find it
- ObsidianRadio
I was just about to post the same thing Such a coincidence!
i think i found it, i couldnt get the cover off though ill do it tomorrow. jack look straight above the fuse box.
Jack, The ones I sent you. One of the plugs is missing but you can work around that...
- shadowarrior
- Tightarse
Does any of these kick plates come with the 'fto' light in red? Or can the bulb colours inside be changed?
Yours truly,
Thread hijacker
Sent from my GT-N7000 using Tapatalk 2
Yours truly,
Thread hijacker
No, they didn't come in red.
They are not bulbs, but EL panels and yes you can buy the EL panels from eBay in different colours.
What I usually do when using EL panels is buy a white one then use a coloured translucent plastic sleeve folder and place it over the top to change the colour. I find that the colour is much more vibrant than the coloured EL panels, especially red.
You could put a 'Gel' over it to change the color, but it will mostly turn out Burple.
EDIT: or do as Vectose mentioned.
I have put a purple translucent folder on mine to make them a darker blue. The thing is, you really need a white EL panel to get the colour you want using an overlay.
- shadowarrior
- Tightarse
Aha! El panels! Thanks for the info Vectose.
- rock_it
The plug us the very top right plug where Dwayne mentioned..
