Hey guys,
Just wondering is there any way to easily remove these from another car and any recommendations for adhesive for applying them to my car?
Thank yous!
Weather strips
- StraydoG
Re: Weather strips
sikaflex!!
Re: Weather strips
You dont need to remove them that way.
Pull the rubber lining out from around the door that forms the seal with the window. Under there you'll see a steel channel screwed in all the way around the door sill. Unscrews all the screws, remove the steel channel with the weather strip intact, attached to it.
- ObsidianRadio
Re: Weather strips
What he said.Bennoz wrote:You dont need to remove them that way.
- StraydoG
Re: Weather strips
looks like the dirty work was done for me, picked them up already removed.
Just need to remove whats left of the old adhesive and install them!
Re: Weather strips
Ah, so in that case, what Matt said. Sikaflex!
