Gearbox problem: Reverse Gear
- Craig
Hey guys
just curious if anyone else has had this problem..and the fix...
Happens only some times, where i cant select reverse gear.
But if i roll forward or backwards just abit it allows me to select reverse..
by the way its a manual....
So if anyone has had this problem and what they did to solve it... that would be awesome if you'd let me know
thanks in Advance
Craig
thanks in Advance
Craig
- Boris
Craig Mate!
Hows it goin!
Yeah, Same thing happened with me- more on Cold starts like early in the morn. But i think its a transmisson/gearbox problem that can occur on any manual car not only FTO's. ( not 100% sure)
But sorry mate this has been a useless post as i have no fix for it!!
But yeah like boris said checking the Gearbox oil wouldnt hurt.
OH and whats the condition of your clutch? new? old?
Hows it goin!
- Craig
Thanks for the replies guys
Its done 110,000km now... all the average 100,000km service done...except gearbox oil... so i might see if that does something...
ive never changed the clutch... i never do burn-outs and quick launchs.. so it's still gripping really well... i have wondered if they could be a reason... but i believe its the gearbox itself... just not lining up properly.. ?
If anyone else has this problem ect.. let me know
thanks again guys!
thanks again guys!
- SilentBob
well as the reverse gear is a one-to-one gear, all manual cars can have this 'problem' if the cogs line up it aint gonna slip in, which is why a clutch-declutch usually means the cogs move a little and it slips in
(from the mouth of a gearbox guy when i was gettin my clutch problem diagnoses)
SilentBob
SilentBob
- SilentBob
- MADFTO
There is on an FTO gearbox =) it's in the workshop manual
Most cars don't bother, as you should be stationary when you go into reverse and double clutching should fix any issues there =P
Don't ask me why they put one in, someone might of wanted to be able to do 180 spins in a manual (laughs at the thought)
- RallyMad
Hi guys, I think this is a thing with a lot of cars. My laser TX3 has a pretty big pressure plate for bitumen launches etc, and I usually can't get reverse when I first start it and used to cruch it all the time trying to force it in. Mechanic mates of mine suggested I move the gears around a little first, by say selecting first then trying reverse again. If that still doesn't work I double clutch and try again and now I can get it following these steps everytime without crunching.
