injectors
injectors
Anyone know if TE or TJ magnas or even 380 injectors fit?
Have set of 380 ones at home but unsure if they work/fit correctly and before I install would be good to know, pretty sure magna 210cc ones do but unsure which model they are off?
Looks at Bennoz :lol:
Re: injectors
do a search, plenty of posts on injectors,
magna 210 /240
diamente 275
VR4 390
all fit
Re: injectors
Yup, anything from 3rd Magna is the go. TE to TJ. Depending on whether it's 3L you get the 210s, or the 3.5L you get the 240s.
Re: injectors
I heard even commodore ones fit on a magna??
Re: injectors
Are they the correct impedance though?
As I heard (but could be wrong) that the 6G72TT injectors won't work on a 6G7X engine
Re: injectors
They gotta be high impedance. But you can run the lows if you have a resistor pack.
Mine were to fit a Nissan 350Z, but in reality they're just a Bosche style, top feed, high imp injector. Nothing fancy about them.
Re: injectors
spetz wrote:Are they the correct impedance though?
Yeah high impedance.
